Author Topic: Graph lines  (Read 2407 times)
Offline iceman
  • Snow is my passion
  • Naples ITALY
    • http://www.campaniameteo.it/NapoliMeteo/NAPOLIultimaosserv.htm
Graph lines
« on: December 14, 2003, 12:40:16 PM »
In the latest version of WD there are some problems with the lines on the main graph and the 24/48/72 hours graphs
The set for the "Use thick lines for the graph" doesn't work correctly
Some lines are thick other no..
Can you controlled this bug?
Cheers Mario
Cheers, Mario
PC:Pentium mmx 225Mhz OS:W2000 Professional : 256 MBRam  WMR 968 Wireless -----
Offline Jim
  • Como, CO and Rio Rancho, New Mexico
    • http://www.southparkwx.com, http://www.albuquerquewx.com
Graph lines
« Reply #1 on: December 14, 2003, 04:21:52 PM »
Brian.
Two more issues with 99G graphs:
1.  Indoor temp is graphed about 20 degrees lower than what the temp is and is indicated.
2.  Again indoor temp, for some time now the indoor temp on the web version only is missing the scale numbers.
The first one might have been around longer but I just noticed, the second one has been around awhile.
Jim
Windows 10, Ultimeter 2100/broadband, (albuquerquewx.com)
Windows 7, Ultimeter 2100/broadband now!, (Southparkwx.com)
Offline Ultima
  • Barendrecht - The Netherlands
    • http://www.aadvanboven.nl/weer/index.htm
Graph lines
« Reply #2 on: December 14, 2003, 05:15:45 PM »
This also happens in 9.97h  (the tick lines)
  • Davis VP2
  • New Zealand
    • Weather Display
Graph lines
« Reply #3 on: December 14, 2003, 07:09:45 PM »
you can set the indoor temp/hum as thick lines
see under (now) setup, graph setup, plot indoor temp/hum
the windspeed lines are not so good looking as thick i think
jim:i have changed the indoor temperature scaling system
it now works independent of the outdoor temperature (and you amy have to reset/adjust the indoor temperature adjust (which is now under setup, graph setup (i shift it form here to the grpah hsitory window me thinks)
email me your wdisplay.ini file from c:\windows or c:\winnt and latestindoor.inf (zip it)
thanks
