Author Topic: Interface Weather Display with Nanhua anemometer  (Read 1711 times)
Offline vinc86
  • Win NT 10.0
  • Chrome 58.0.3029.110
« on: June 06, 2017, 08:33:58 PM »
Hello,
this is my first topic on this interesting forum. I'm an Italian meteorologist.
Recently, I've purchased a Nanhua anemometer (model FA21: http://en.nanhua.com/products/Anemometer/FA21/). The wind sensor is connected to the FA220C datalogger (http://en.nanhua.com/products/Anemometer/fa220c/). The latter communicates with PC via RS485-USB cable. I would connect this anemometer to Weather Display: is it possible to create an "ad-hoc" interface setup?
I await a feedback.
Thank you.
Vincenzo Capozzi
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Interface Weather Display with Nanhua anemometer
« Reply #1 on: June 07, 2017, 08:05:47 AM »
is there an RS232 option?
Offline vinc86
  • iOS 10.3.1
  • Safari 10.0
« Reply #2 on: June 08, 2017, 09:42:51 PM »
No, unfortunately, the anemometer can ne connected to the PC only with a RS485-USB cable.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: June 09, 2017, 03:29:52 AM »
I think you can get RS485 -> RS232 hardware convertor?
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #4 on: June 09, 2017, 02:23:00 PM »
If it already uses an RS485 to USB converter at the PC end I'm not sure you need to worry about RS232. Need to know the interface protocol though.
Offline vinc86
  • Win NT 10.0
« Reply #5 on: June 11, 2017, 09:27:15 AM »
According to the guidelines provided by Nanhua manual, the connection between datalogger and PC can be performed only via RS485-USB cable.
I hope that we can find a solution. The Nanhua software generates a .txt file that contains the average wind speed and wind direction data. The file is updated every 10 second. As an alternative, we could find a solution to read those files through Weather Display (as it occurs for the .dat files generated by Campbell datalogger).
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: June 11, 2017, 05:52:15 PM »
that will work, getting WD to read the text file
Offline vinc86
  • Win NT 6.3
« Reply #7 on: June 12, 2017, 07:14:23 AM »
Ok, this is a good news!
How we can interact about this topic? Maybe I could send you an example of this .txt via email.
Let me know.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: June 12, 2017, 09:40:47 PM »
yes, that will be the first step  :wink:
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: June 18, 2017, 11:10:15 PM »
I have added support now
see my reply email
Offline icemannapoli
  • Naples - Italy
  • Win 7/Srvr 2008R2
  • Chrome 59.0.3071.115
    • http://www.campanialive.it/dati-meteo.asp?stazione=napolivomero
« Reply #10 on: July 21, 2017, 06:17:58 PM »
Hi Brian
Along with my friend Vinc86 we tried viewing through the txt file but it does not work.
we used latest version of WD select the txt file but not work..
Suggestion ?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: July 29, 2017, 02:47:06 AM »
that should work
as long as the file you have selected in WD is being updated
if you could .zip and email me that file you have, and the wdisplay.ini setting file, I can test/check here
  • Naples - Italy
  • Win 7/Srvr 2008R2
  • Chrome 60.0.3112.101
« Reply #12 on: August 18, 2017, 10:58:32 PM »
good news
i partially solved
the Nanhua text file path must be under wdisplay directory to work.
But now i have another problem too...
into Nanhua txt file 2.9 m/s are written without comma decimal separate  Example:  2.9 m/s as 29
4.5 m/s as 45
Wd read 4.5 as 45
it's possible for you to correct this problem?
the Nanhua txt file is:
00:00:00 28 226
00:00:10 30 222
00:00:20 28 219
00:00:30 26 229
00:00:40 27 239
28,30,28,26,27  must be 2.8,3.0,2.8,2.6,2.7
thanks a lot
Mario
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
« Reply #13 on: August 18, 2017, 11:12:07 PM »
yes, that is an easy fix
the file problem must have been a permissions problem then in the original folder
  • Naples - Italy
  • Win 7/Srvr 2008R2
« Reply #14 on: August 18, 2017, 11:27:26 PM »
okay
for the decimal comma ? can you solved?
29 for WD should be 2.9 m/s ;)
actually 29 is 29 :D
